Sometime around 20/8/08 (at 12:07 -0400) deidremc said:
i didn’t realize FW worked best with tiff.
It isn’t actually the case that Freeway ‘works best with TIFF’. In
fact, Freeway is happy with whatever image format you care to use, as
long as it is one of the many that it can read. It will output
web-optimised graphics when you publish your pages, regardless of
what format you import.
If you save an image in JPEG form, the compression process throws
away some of the image information. When it is processed as a
web-optimised graphic (I’m assuming JPEG format) as part of the
publishing process, it is compressed once more. This happens from
scratch (no other way to do it), so it goes through a second lossy,
damaging compression process.
THAT is why it is best not to work with JPEGs. However, if you have
been given the images in that format there’s nothing you can do to
avoid the scenario above. As long as you don’t plan to edit and
resave the images there’s actually no real point in resaving them to
a different format.
Conversely, if you DO intend to do anything to them and save them
afterwards before using them in Freeway - for example, adjusting the
contrast or levels, or resampling to a different pixel size - then
you should save them in a non-lossy format. In this case, TIFF is
fine. As is native Photoshop (PSD) or PNG, or a number of other less
common formats.
If your photographer doesn’t shoot photos in RAW format then it is
incredibly unlikely that they are recorded in anything other than
JPEG right from the start. In which case you might as well receive
them in JPEG form as they’ll take less time to send online, take less
space on a CD, and so on. However, if the shots are recorded in RAW
format then having the photographer process them as TIFF is one of
the right things to do.
the original pixel size is 3872 x 2592. if i was going for a screen
size of about 2 inches, do i resize in GC for 216 x 144?
IF that pixel dimension looks right when you draw out a box of that
size in Freeway, then yep, absolutely. It ain’t large, that’s for
sure, but it could well be just what you need. I suggest importing
one of the full-size images and scaling it down to see what size fits
your design, rather than working from an abstract idea of ‘about two
inches’. Once you have the image scaled down and the box shrunk to
fit, read off the pixel width and height from Freeway’s Inspector
palette. THAT will be the ideal size to make them, assuming you will
never want the option of zooming in to show a portion of the image.
k
