Just noticed that when trying to open a 2 year old Intaglio document, either by double clicking the document or via File>Open, Intaglio crashes every time on launch with a
Exception Codes: KERN_PROTECTION_FAILURE at 0x00000000bf7ffff4
Other more recent documents can be opened, and new documents saved with no problem. First noticed under 3.3, but still occurs after upgrading to 3.3.1.
Running OS X 10.7.4 (11E53) on Model: MacPro3,1 with NVIDIA GeForce 8800 GT and 32 MB RAM.
This is an important issue that the developer will wish to investigate and fix. Send the crash report along with the file that caused the crash and a copy of your description (above) of the steps required to reproduce the problem to Nick Nallick email@hidden.
I’ve now sent a copy one of several files causing the crash-on-launch, along with a crash report, to Nick at his request. Will update if / when root cause is identified.
I do wish that Nick would stop playing about with the file format. Not even version 3 files are compatible between different sub-versions. If this is going to keep happening then we will need a facility to save to a version number, especially once Nick decides not to support 10.4.11 any more.
