I have a few questions and hope someone can answer
- why is it that when I drag an image onto the page it becomes very small? tried with jpeg and png.
- why my fonts in the page preview display as Times new roman when the actual font selected is Ariel?
- why is there only 1 undo? the rest of the world is on unlimited (almost)
That’s it for now
thanks for your help
Eldad.
Hi Eldad,
Freeway pays attention to the pixel-per-inch resolution setting of
images unless told not to. If an image is set to be 300ppi (pixels
per inch) that makes it arrive on a DTP page at a certain scale, and
it does the same thing in Freeway too.
If you want Freeway to ignore the ppi resolution setting you must
import by selecting a graphic box and choosing File > Import. Click
the Ignore Resolution checkbox before clicking the Open button.
Hard to say without more information. How have you set the text? Is
this HTML or graphic text?
Well, multiple undo is increasingly common, although unlimited is not
quite as normal. The trouble is that, in Freeway’s case, I’m sure
this would require serious and complex changes to the application
structure and quite possibly the document structure as well. It is a
long-requested feature - my guess is it’ll be here one day, but I
don’t expect it imminently.
Oh - one small point: you’ll get more response if you post to the
main Freewaytalk forum/list instead of this Tutorials one.
k
tutorials mailing list
thank you! didn’t realized it was the wrong forum %-)
the text is is set to html, I did’t have hat with my last hard drive, had to replace and reinstall. at first I thought I didn’t have the font, but I do. and it’s nothing special, just ariel…
very strange.
thanks for your help.
On Mon, Feb 2, 2009 at 8:05 PM, Keith Martin <email@hidden> wrote:
Hi Eldad,
Freeway pays attention to the pixel-per-inch resolution setting of images unless told not to. If an image is set to be 300ppi (pixels per inch) that makes it arrive on a DTP page at a certain scale, and it does the same thing in Freeway too.
If you want Freeway to ignore the ppi resolution setting you must import by selecting a graphic box and choosing File > Import. Click the Ignore Resolution checkbox before clicking the Open button.
Hard to say without more information. How have you set the text? Is this HTML or graphic text?
Well, multiple undo is increasingly common, although unlimited is not quite as normal. The trouble is that, in Freeway’s case, I’m sure this would require serious and complex changes to the application structure and quite possibly the document structure as well. It is a long-requested feature - my guess is it’ll be here one day, but I don’t expect it imminently.
Oh - one small point: you’ll get more response if you post to the main Freewaytalk forum/list instead of this Tutorials one.
k
Okay, in that case it might help if you upload a sample page
somewhere where it can be seen online. But it would also be good if
you asked this in the main Freewaytalk forum as you’ll get far more
people reading it!
k
