I know others have mentioned it, but it can be REALLY annoying !! Presumably this is a difficult one, not to have been fixed already ??
K
K
Sorry, can’t tell what you’re asking about here. Do you have an example of the problem? Does it happen in all browsers or just some? Are the pages different lengths (and the layout centered)? (That last one is a very common question answered here – the answer is “make all your pages taller or just realize you can’t fix it”.)
K
My apologies Walt, I didn’t make myself very clear. I meant in Freeway, not browsers.
Very often you select an item on a page and it can shift position quite easily when clicked, unlike other apps. For example sometimes I click an item and I think “did that move or not?” so to be sure I hit +z just in case. If it didn’t move I end up Undoing my last action on another page. It does seem to be a particular bug with FW. I just wasn’t sure if SP are going to fix this sometime?
K.
Hi Kryten,
This happens issue happens to me as well but apparently, not as often as it does to you.
If it does happen that you end up undoing your last action on another page, pressing +z again will redo that same action. A couple of other suggestions are to have the inspectors panel always shown - so you can see if the coordinates change - or to lock the item in place.
Bryan
