Is there a way to pre configure the MetaTags action entries. This way one would’t have to enter the same data over and over each time they tried a different layout.
If you create your meta tags on the Master Page, they will trickle down to the instance pages based on them. Also, if you duplicate an existing page, the duplicate will inherit any changes from default, so Meta tags would come along as well.
come along as well.
Also, once I get a basic layout that I like - maybe it has the webfonts I
like or some styles and colors - even the meta tags I use all the time like
“author” - then I save it as a Freeway Pro template and all my favorite
stuff is already “built-in”
