This is a odd. I can no longer see my Actions pop up window? No matter where I click to get it to show it will not - see image - its impossible to get that tick to show up next to the word Actions??? Is my Freeway corrupt?
perhaps moved it accidently in a far corner? Hidden behind another window?
Is there an action active?
Op 7 jul. 2014 16:48 schreef “Justin Easthall” email@hidden:
Your preferences may be corrupt. Try making a new Mac OS X user, sign in as that user, and then see if the normal behavior obtains. You may be able to get out of this by simply finding and deleting your “~/Library/Preferences/com.softpress.freeway*” files while Freeway is not running.
On Jul 7, 2014, at 11:10 AM, Justin Easthall wrote:
Thanks but - see the image - if it was active there would be a tick next to it - it won’t become active in the first place… def not hidden
There should also be a Freeway Pro Preferences file in there. Can you try removing that too? Make sure to empty the Trash before starting Freeway back up.
On 7 Jul 2014, at 16:22, Justin Easthall email@hidden wrote:
Ok worked as a diff user - so went to pref ext all I see is this one com.softpress.FreewayPro.plist which I deleted - but didn’t work?
