Add a Flash Carousel to a Freeway Page
As a request from eus here: http://www.freewaytalk.net/thread/view/40869
I’ve added a tutorial how to add a Flash Carousel into a Freeway pages here:
http://www.ineedwebhosting.co.uk/blog/
tutorials mailing list
I have uploaded my carousel to my server, but cannot see the images. The images have been uploaded to the server for sure, as I checked for them in the control panel file manager. Also, each time I upload to my server, it creates a new file called defaulta.xml, defaultb.xml, etc. Maybe the images are in the wrong spot?? Don’t know, I am new at this. Please help. I have been working for about 6 hours on this.
Hi there,
If you are certainly right that the images are in the right spot.
Try this. I had this several times!
When it is .jpg rename it to .jpeg.
Several times with different occasions i had this as solution!
Good luck!
marianne
Did you try deleting the file that has the added “a,b,c,d” etc from the Resources folder in Freeway? (after first backing it up somewhere just in case Freeway tanked your file.) I know, I know, don’t mess with the Resources folder, but sometimes Freeway gets confused and does this. Sort of how it handles graphic items that share the same name. Strange.
Do you have a sample page to look at so we can dissect the problem?
…The images have been uploaded to the server for sure, as I checked for them in the control panel file manager. Also, each time I upload to my server, it creates a new file called defaulta.xml, defaultb.xml,
Personally I have used an FTP app like Transmit to upload the default.xml and image files so that FW cannot mess with them. I find it easier to put the images in their own folder “carousel_images” for example and give them generic names like image1.jpg, image2.jpg so then I can change the images by just uploading a revised image1.jpg without having to change the default.xml file. Just make sure that the path to your image folder is correct in the default.xml file.
Thank you all for responding. Ok, here was the problem. default.xml was uploaded to the resources folder, but it was in the wrong path. The file kept looking for it in my html folder. So I moved it along with the jpegs and presto!! Now if I could just figure out why my htaccess file is empty. Oh well, I keep learning! But thanks for all your help everyone!
good evening (or really good morning) to all! I am very interested in this action and am trying it out… and will try some of those tips listed above. I want to use this on a page with other things - is this possible?
Its not an action, its a tutorial telling you how to get the Flash
carousel working inside a Freeway page.
http://www.ineedwebhosting.co.uk/blog/how-to-add-a-flash-carousel-in-freeway/
Yes it will work along side other things on a page.
is this possible?
Thank you david,
I have this “working” but not finding the images that are loaded
I have them in the main folder
here is what is going on:
www.grdesigns.net/iphoneapp
can you help please? thank you again
J:)
is this possible?
David_______________________________________________
Hi Julie,
It looks like the Carousel cannot find the images.
First thing to check is, have your image been uploaded? and if they
have, where are they?
Have you put your images into an (images) folder and uploaded this
(images) folder to your main directory?
Ok, you have two choice
On 6 Mar 2009, at 12:47, Julie Maxwell Allen wrote:
Thank you david,
David Owen :: Freeway Friendly Web hosting and Domains ::
http://www.ineedwebhosting.co.uk :: http://www.ineedwebhosting.co.uk/blog
Thank you I fixed it!!!
ahhhh one stress down!
On Mar 6, 2009, at 8:44 AM, David Owen wrote:
Hi Julie,
Thank you david,
Dear David,
I followed your carousel tutorial and managed to get the basic version working but I wanted to incorporate Lightbox into the equation, as per your link, but I get lost in all the basic scripting required in Lightbox. (Probably because I’m a very novice user of Freeway.)
Do you have a more advanced tutorial that goes through the exact steps to incorporate Lightbox into a Carousel within a Freeway webpage?
Oliver
20 apr 2009 kl. 20.19 skrev Oliver Cukor:
Dear David,
Where can I find it?
Arne
Arne,
Oliver
20 apr 2009 kl. 20.51 skrev Oliver Cukor:
Arne,
Thank you so much!
May I ask you, if you know of any easy to
learn / how to build a site in FW?
Cheers, Arne
Arne,
Try the tutorials at the Softpress site.
http://softpress.com/support/freewaymoments.php
Oliver
Hi Oliver
Sorry I don’t. I will try and update the post when I get a moment free.
On 20 Apr 2009, at 19:19, Oliver Cukor wrote:
Dear David,
user of Freeway.)
webpage?
Oliver
Thanks David.
I will look out for it.
Oliver
Dear David,
One more thing. Do you know anyone experienced enough to do this project on my behalf? Or do you do freelance web work?
Oliver
22 apr 2009 kl. 00.01 skrev Oliver Cukor:
Dear David,
Dear Oliver and Dear David!
Where is the Flash Carousel itself…? :wink:
THAT I am interested in!
And to see how it is being done.
Cheers, Arne
