I am building an online archive site for 147 issues of a community newspaper. I am interested in seeing if the Typesense search engine might be integrated into the site to provide search results from the site pages and the newspaper files. The newspaper page files will be in html generated by Google Vision OCR using NLP.
I asked Claude about a possible work flow and got the answer below.
Any advice would be helpful. Thanks.
Paul
To add a search engine to a flat website using Typesense, you first set up a Typesense server (self-hosted or via Typesense Cloud), then use its InstantSearch.js adapter to connect your site and display search results with a simple JavaScript widget.
Setting Up Typesense for Your Flat Website
To integrate a search engine into your flat website using Typesense, follow these steps:
1. Set Up Typesense Server
You can choose between two options for setting up your Typesense server:
- Self-Hosted: Install Typesense on your own server.
- Typesense Cloud: Use the managed service for easier setup and maintenance.
2. Configure Your Typesense Collection
Once your server is running, create a collection to store your searchable documents. This involves:
- Defining the collection name.
- Specifying the fields to be indexed (e.g., title, description).
3. Index Your Data
Upload your documents to the Typesense collection. This can be done using the Typesense API, where you send your data in JSON format.
4. Integrate InstantSearch.js
To display search results on your website, use the InstantSearch.js adapter. Here’s how to set it up:
Install InstantSearch.js: Include the library in your project.
Create a Configuration File: Set up a JavaScript file to connect to your Typesense server. Here’s a basic example:
javascript
import TypesenseInstantSearchAdapter from “typesense-instantsearch-adapter”;
const typesenseInstantsearchAdapter = new TypesenseInstantSearchAdapter({
server: {
apiKey: “YOUR_API_KEY”,
nodes: [
host: “YOUR_TYPESENSE_HOST”,
port: 8108,
protocol: “http”,
additionalSearchParameters: {
query_by: “title,description”,
5. Implement Search Functionality
Use the InstantSearch.js widgets to create a search interface. Here’s a simple setup:
- Search Box: For user input.
- Hits Display: To show search results.
- Stats Widget: To display the number of results found.
Example Code Snippet
javascript
const search = instantsearch({
indexName: ‘your_collection_name’,
searchClient: typesenseInstantsearchAdapter.searchClient,
search.addWidgets([
searchBox({
container: ‘#searchbox’,
placeholder: ‘Search…’,
hits({
container: ‘#hits’,
templates: {
item(hit) {
return `
search.start();
6. Test Your Search
After implementing the above steps, test your search functionality to ensure it works as expected. Adjust the configuration as needed for optimal performance.
By following these steps, you can successfully add a search engine to your flat website using Typesense.
