Hi. I’m fairly new to creating pages and using Freeway 5 (beta 3). Anyway…On one of my pages I want to do some very simple calculations based on what someone enters into a box. It’s static calculations, nothing fancy. Just multiplication. then i want the results to display back on a separate page so they can print it out. It’s basically for showing them how much something will cost given the amount of things they enter.
How can I do this easily or where can I get help? Thanks so much.
If the answer had to be on the same page, Javascript would do it. As
it’s a different page, that page has to be generated dynamically
according to the answer, so you’ll need PHP or similar.
HP-UX specialist of hpUG technical user group (www.hpug.org.uk)
www.ivdcs.co.uk
