Alpha Mask?
I’m am trying to follow the Fireworks tutorial at http://www.communitymx.com/content/article.cfm?cid=4CB81&print=true in an attempt to reproduce the Intaglio Sample graphic “Aqua Button”. Everything has gone great until I try and apply the Alpha Mask that is supposed to add a hint of transparency around the caustic (glow). I’m pretty sure it is using a CI effect, but I can’t figure out which one, and then I’m guessing the final step uses the “Paths” sub-menu?
Can anyone clear this up for me? I have my Alpha Object created, but no matter how I try and apply it to the button it doesn’t come out right.
Any assistance is greatly appreciated.
Thanks!
Pablosan
Intaglio mailing list
Are you talking about the object that appears in Figure 8 of the example? In Intaglio that features uses an intensity mask on the group object (see the group inspector at Window > Group). If you ungroup the object you’ll probably see what’s going on.
This sample Intaglio file may help you.
http://myweb.tiscali.co.uk/jesdesign/files%20download/files.html
John.
Yes, Figure 8 is it exactly. And checking Intensity in the Group palette is exactly the step I was missing.
Thanks for the help! Having only used the app for a few days, I’ve been very impressed with it so far. It has already proven to be money well spent!
Thanks again,
Pablosan
Thanks, John! A very useful sampling, indeed!
slight update to the file because a couple of the text samples that have patterns applied did not display has intended.
John.
