Anyone using sIFR Typography with Freeway?
Hi Paul,
Just a quick question regarding your excellent sIFR plugin, if I may… I’m using it with Freeway Pro 5.1.1 and it seems to generate all of the required code apart from the links to the javascript file.
Do these have to be added manually, or should the plug-in do this for you?
Best,
Craig
dynamo mailing list
HI,
It’s a Freeway 3 Action which was tweaked for Freeway 4. I haven’t even looked at it in FW5 yet. It’s possible that something has broken. I just don’t know what yet.
dynamo mailing list
No worries Paul, just thought I’d ask the question.
If you ever do get time to look into it, I’d be willing to help test it out.
Craig
dynamo mailing list
