Hello,
How can use the automator actions in intaglio : e.g. rotate intaglio
graphics, translate intaglio graphics, etc. ? I have never used and I
don’t find any explanation in the help menu of automator about how to
work in a file
mac os x 10.4.11
jacques
Yes, Intaglio is very scriptable so it works well with Automator. There are some predefined Automator actions included with Intaglio so once you’ve run Intaglio, Automator should find them automatically. These actions are mostly related to importing and exporting images. You can script just about anything else (e.g., rotation and translation) as a custom action. If you have something specific in mind I might be able to help you.
