##What is Available Width?
Available width is the Freeway term for what we used to call undefined width. In code terms, it produces no defined width value for an html item. In inflow layouts, this setting will cause an html item to expand to fill the available width of its container.
##What is Percentage Width?
Freeway also allows the user to set an html item’s width as a percentage of its parent container’s width. A width setting of 100% will cause an html item to also expand to fill the available width of its container.
##What’s the difference between Available Width and 100% Width?
In the normal document flow, there is no difference. An item of undefined width and an item of defined width:100% would both expand to fill the available width of their respective containers. The only difference I can imagine (but have not tested) might be in the case of floats where such items would be removed from the normal document flow and behavior.
##So what is the squabble?
I have no idea.
width:100%; max-width:600px;
is effectively the same thing as…
max-width:600px;
on an item with no width setting (available width). Every browser produces the same result and they are both backwards-compatible as far as I can see.
Max-width
is not a width setting, but a width limiter-- it only applies to flexible width items, not fixed dimension items, and only sets an upper limit for these items to expand to. The setting for this can be found in the Dimension Pane of Freeway’s Inspector.
