Is it just me or is Background Supersizer not friendly towards placing transparent png images on top?
Specifically - I have a logo I’m trying to drop on top of the BG and it always results in having white jagged edges around it - be it a PSD, PNG - regardless of the source or size… The exact same pngs on a solid color background do not have this issue.
Thanks, yes - they are layers. Since then I’ve still been playing with it and it’s starting to look like it has something to do with the resizing of text graphics.
For now I’ve dropped the logo and gone with html text and a matching CSS menu. This is just for a splash page that’s primarily about the BG images - so no great loss.
Are your Freeway Pro png images settings at millions? Have you tried
bringing it in as a pass-thru .png image?
text graphics.
Thanks Ernie - After a lot of file size manipulation/shrinking in Photoshop I finally got it working satisfactorily with pass-through - which needed the check-box to be on during import. doh
The BG images are another issue - it looks great on the desktop using (9) 3-5mb+ image files, but on upload - it chokes the bandwidth and takes forever to load. Shrinking everything to 800px (roughly 300K/file) works better, but it’s not pretty in a large window (27" monitor).
Thanks David - good idea, I replaced them with 1200px @jpg8 compression - and it is better - not perfect - but better. I’ll keep playing with that approach and see if I can optimize the settings.
For my purposes, I keep my background images at 1600px and use Photoshops’
Save for Devices feature, targeting a compressed size range of 150k to
170k.
