blog issue
Good afternoon.
I am having a blogger issue and was hoping that you can help.
If you look at this blog:
http://kincaidandassociates.blogspot.com
there is a white line on the right . - which I have NO CLUE what it is… and how do I remove it?
also the posts box is not showing - should be right under the about me.
any help with this would be gratefully appreciative.
thank you
Julie
You have two divs with the same id value (header) and the top one has a
background color of white ( #header { background-color: #fff; } ) so they
are both white.
I’ve never done a blogger template, so I’m not sure how you accomplished
this. Normally, Freeway Pro doesn’t let you make two items with the same id
value so one of them is markup and the other is normal Freeway Pro. My
money is on the top one for Freeway and the bottom one (
) as Markup or none-FWP generated.
On Mon, May 13, 2013 at 3:12 PM, Julie Maxwell email@hidden wrote:
Good afternoon.
thank you
Julie
