Blogger Actions problem
I have been experimenting with the Blogger Actions.
The instructional video is good, but I suspect it and the Actions were
recorded/written before Google performed some sort of update?
The font I use on the site is Verdana. So I have changed all the font
references in all the dialog boxes in the actions palate to Verdana.
After finally finding the correct webpage to paste the HTML code into the
Google Blogger Template, I saved the Template, I then got the following
error message:
Warning: Your new template does not include the following widgets:
Followers1
Attribution1
Would you like to keep these widgets on your blog or delete them?
Deleting widgets cannot be undone.
[Keep widgets] [Delete widgets] [Cancel]
As it says something about “Deleting widgets cannot be undone.” I said keep
widgets.
When I view the template in a browser it looks decidedly wonky, most fonts
in Verdana but some in a serif font. This may be controllable in the Google
settings page?
I’m assuming the blog has to be viewed from the Google address?
http://scolopax-blog.blogspot.com/
Best wishes Peter
Peter Tucker, Oxford UK email@hidden
