Right now the actions don’t support what you’re trying to do. What you’ll have to do is take the code once you choose the “Publish To Clipboard” in Freeway and paste it into Blogger. Then check the box that says “expand widgets…” and then select all the code in the box and copy it to a text editor. I use TextMate, but TextWrangler is free…and then follow the instructions of this site:
http://www.eblogtemplates.com/how-to-add-the-blogger-read-more-expandable-posts-link/
Which will require you to do a search for some specific lines of code and then you’ll have to go in and add the snippets and then make the “span id” change in Blogger itself. The problem is that if you make any changes to your site you’ll have to go in and re-do this over and over.
But that seems like your only option for the time being.
