Blogger Trouble despite instructions.
Hi guys,
I have read several sets of instructions on here to figure out what I’m doing wrong with my Blogger actions. I still have not found the solution.
Basically, I have built a blog with the FW5 actions. There are Blogger Posts, a header, an archive, and my profile. I uploaded them via FTP to my host. That is located at http://www.rockyslaughter.com/blog .
When I copy the HTML to the clipboard via the Blogger Action, I insert it into the “Edit HTML” function on Blogger. I have done it under “Layout” and keep getting error messages with both the widgets expanded and not expanded. Then, I have reverted my blogger account to the “Classic Template.” No error messages when I do this, but the background image and color disappears, the different Blogger actions do not appear on the page and the annoying Blogger NavBar is displayed prominently at the top. If you want to see this version you can view it at
http://blog.rockyslaughter.com
I have had success with Blogger actions before. I just must be doing something wrong.
My HTML is set to XHTML 1.0 strict.
The error message I get when copy/pasting into the Layout is that “Your template could not be parsed as it is not well-formed. Please make sure all XML elements are closed properly.
XML error message: XML document structures must start and end within the same entity.”
Can anyone help with this one? Thanks.
Rocky
