After just digging around on the Lightbox forum (Lots with similar issues),
http://www.huddletogether.com/forum/comments.php?DiscussionID=1815&page=1#Item_0
It mentions here:
“By trial and error, I’ve determined that Lightbox and IE don’t like the “position:absolute” bit of the div.”
On 19 Aug 2008, at 15:22, Walter Lee Davis wrote:
No, this is just an example of the code I posted earlier in this
thread, one which you could try out on your own system. As I noted,
it is broken in exactly the same way as your Lightbox code, and
doesn’t actually improve on that code in any way. The reason why I
did the separate inside and outside versions was to see if that could
work around the issue.
What I have been able to deduce so far (and I did do some tests with
this page, adding and deleting CSS code to see if I could force it to
work with a “vanilla” Freeway page) is that when you have a page with
absolute positioning, as most Freeway CSS layout pages tend to be,
then you will have this problem.
My guess is that a page coded with all of the elements as relative
positioned inline neighbors (using floats and clears and margins
rather than absolute x/y positioning) might not have this issue. That
would explain why the effect would work on a non-Freeway site.
I would love to be proven wrong on this, maybe Ernie has some
thoughts on the subject…
On Aug 19, 2008, at 10:08 AM, David Owen wrote:
Hi Walter,
I’m not sure where you’re going with this. Its only the Freeway
standard styles preventing it from working. But I’m not sure in
which combination. Other non-Freeway sites work OK with lightbox
and overlay in IE with body { margin: 0; padding: 0; }. So I
thought by deleting/amending the right styles it would work. But
anything I’ve tried so far just does not work.
Are you saying a new overlay is used in preference to the overlay
lightbox.js is creating?
On 19 Aug 2008, at 14:29, waltd wrote:
Here’s an example of a simple overlay div, set to 100% height x
width, appearing and disappearing at the whim of the visitor. It
works in IE6/XP, don’t have any other flavors of IE to test with.
http://scripty.walterdavisstudio.com/overlay
If the page is shorter than the window, then it works just fine.
But if you scroll the window up to force vertical scrollbars, then
the problem occurs here as well. It doesn’t seem to matter if the
overlay is inside or outside of the PageDiv, either.
I’ll fiddle with this a little more.
David Owen
Printline Advertising
4 Chapel Hill, Yeadon, Leeds LS19 7RG
Tel: 0113 2508606 Skype: PrintlineAdv
http://www.PrintlineAdvertising.co.uk
Creative Design, Print, Copy, Web Design,
http://www.printlineAdvertising.co.uk/hosting
Web Design, Web hosting, Domain Registration
http://www.TheLogoWorks.co.uk
Logo Design, Corporate Image.
http://www.printlineadvertising.co.uk/Cat
Online Promotional Gifts Catalogue
