Bullet Color
Hi All,
Can anyone tell me how to change the color of bullets in a paragraph
list? Thanks!
Richard
FW Pro 3.5.12
Richard Houston
Architectural Art
http://www.richardhoustonart.com
There’s a couple of ways to do this…
The easy way is to use Tim Plumbs neat little action
http://www.freewayactions.com/product.php?id=010
which allows you to use a graphic item as a bullet
The more complicated way is to use a bit of javascript like this although its a bit overkill if this is all you need to do.
http://morecss.yellowgreen.de/list-style-color-demo
all the best max
Are you still using Freeway 3.5? If so, there’s a bug in the way it
codes bulleted lists which means that the markers always come out
black even when the list items are made a different color. Tim Plumb
wrote an Action a very long time ago to fix this. You should look at
his http://Freewayactions.com site to see if you can find it there, or
it might be on the ActionsForge by now, too. It’s not needed in more
modern versions of Freeway, which code the list items correctly.
FreewayActions.com | List Item Images
all the best max
On Mar 11, 2010, at 2:15 PM, Walter Lee Davis wrote:
Tim Plumb wrote an Action a very long time ago to fix this.
Thanks Walter. I tried applying Tim’s “List Item Fix” action to the
text (html) box that holds the bulleted list. It shows that the action
is applied, but nowhere can I find how to change the color of the
bullets. It must be right in front of me, but I don’t see it. Can
anyone help? Tim?
Richard
FW Pro 3.5.12
Richard Houston
Architectural Art
I tried applying Tim’s “List Item Fix” action to the text
Max was suggesting that you use Tim’s List Item Images action (not List Item Fix) FreewayActions.com | List Item Images
And insert a graphic the right colour!
Sorry I didn’t read this slowly enough
It shows that the action is applied, but nowhere can I find how to change the color of the bullets.
You dont actually change the bullets themselves - you style the list items (colour) and this is applied to the bullets too.
What it wont do is let you have different coloured bullets compared to the text next to it. You will need to use List Item Images to get that effect.
You can also do it without images and a little extra markup. Though
not the last word in lean code the hit is still small and it works.
Each list in this example uses slightly different markup. Pick the one
you like. http://www.xiiro.com/demo/bullet/index.html
Hi Richard,
From memory the action moved the list items inside of the font tags
(shudder) which will cause them to pick up the same colour as the text
but will invalidate the HTML. Unless you are using HTML 3.2 I would
suggest using CSS to style the list items.
the bullets. It must be right in front of me, but I don’t see it.
Can anyone help? Tim?
FreewayActions.com - Freeware and commercial actions for Freeway
Express & Pro.
Spam.
On Mar 12, 2010, at 4:03 AM, Tim Plumb wrote:
Unless you are using HTML 3.2 I would suggest using CSS to style the
list items.
Thanks Tim, David, Max, Walter and Todd. I’ll experiment with your
suggestions.
Richard
Richard Houston
Architectural Art
