This is better than that first glass of Chablis of the evening.
K.
K.
I am close to finishing the next release of the action suite 2.2 and one area that has had some work done on it is the spawn window function
You can see a quick example of it here:
http://www.max-izzat.co.uk/popup/index.php?WEBYEP_DI=1
As you can see I have only populated the first couple of pages but you can see from this example the update makes this sort of function a lot easier
This example was created in freeway using one main page for with 3 Webyep thumbnails which in turn are in a loop, there is a rough webyep menu on the right which allows me to make as many pages as I like and I have three duplicate popup windows which are used by the three thumbnail in the freeway artwork
I hope to release this update soon but will probably be after the Freeway 5 launch of mid March.
max
I forgot to mention that all the text in the example is also uploaded via webyep
max
