Does Carousel 2 not work with Freeway 7 Pass-through images?
That is correct. You need to follow these steps to work around the difference in construction:
I plan to revisit this Action at some point, and make this whole process unnecessary. The issue is that Freeway made DIVs around pass-through images in versions < 7, and does not bother with that in 7. The DIV was what I was using to build the effect.
Hi Walt
Thanks for this, it certainly got the Carousel action working but unfortunately I can get the pictures to work responsively - any suggestions. I have tried string the html box to Fixed% and/or the graphic box to Fixed% but the size stays static when I resize the browser.
you can’t set carousel responsive cause it requires width and height.
Is there anything that will work in responsive e.g. Fading Slideshow?
I’ve been using Exhibeo’s Slideshow presentation quite effectively in
responsive layouts, but it requires hacking both Freeway’s and Exhibeo’s
CSS.
I’m a designer with no knowledge of coding - which is, of course, why I use Freeway
use Freeway
So, you use Freeway with no knowledge of coding… not even a little bit?
What’s the emoticon for the raised eyebrow of disbelief?
I learned almost everything I know about front-end coding from using
Freeway Pro!
Yep - I’m afraid so
Hi Kevin, have you tried WOW slider? Latest version produces fully responsive slideshow with a wysiwyg interface.
All that is required is a couple of lines of code pasted into your freeway document.
On 19 Sep 2014, 5:09 pm, Kevin McElligott wrote:
Yep - I’m afraid so
Hi Mark
This is great. Which part of the code do you paste into Freeway. Do you create an iFrame and use that or create a markup item?
Got it
Head section pastes into Page>html markup>after
Body section goes into Inset>markup item
Thanks for all your help - much appreciated
Got it Head section pastes into Page>html markup>after
Actually, it’s usually recommended that you put it before the tag. ![]()
Thanks Caleb
I have now put that right
