Have a look at the carousel I just uploaded (Sorry, it is in Dutch…) www.healthschool.nl
Looks fine. Have a question though: on the homepage I actually want to make links to a specific pane. Now any link goes straight to the first pane called ‘healthschool’.
If you want to link to a particular pane from the same page as the carousel is on, simply make an anchor link (manually) to the name of the pane. If your pane was called foo, you would enter #foo in the URL.
If you want to link from another page to the page where your carousel is, and have a non-default pane slide into view, then use a question mark to indicate this. Make a manual link to mypage.html?foo and mypage will load, and then foo will scroll into view.
