Hi,
I have a problem with my site. I’ve applied a carousel action and at first it worked fine, but out of the blue it all stopt working???
http://www.kledingbeurs.be/test/
Where is the Carousel supposed to be on your site?
There are a load of unsafe javascript errors to do with twitter and facebook iframes which may well be causing your problems.
Hi Dave,
The carousel is on the homepage, if you press on one of the menu-items above, the text should ‘carousel’ below. It worked all fine.
where can you see that there are unsafe errors?
Thnx.
