Carousel Questions
Hi all, a couple quick carousel questions.
1-Are the instructions at the demo link of actions forge now current?
2-Is there a limit to how many carousels that con be used on a page?
3-Can on carousel be placed within another? What I want to do is move between panels from left to right and be able to have a carousel in each of those panels that moves vertically.
Thanks, TeamSDA_Dave
  1. Yes.
  2. The only limit is your visitors’ patience. Everything you place in a carousel becomes part of the initial page download size.
  3. No.
Hi Walt,
Thank you for the response. I have been waiting to try this action and it seems like it is now quite solid. Your instructions and styling tips are awesome. You have made the whole thing so simple.
As for trying to nest carousels in one another, I had gone ahead and tried it and yes it turned into World War 3. If it could ever do this it could open the door to even more creative possibilities.
Also I have read past post where other users have desired the action to allow for looping back around from last frame to the first. Just want to ad my vote for this feature as the zip back can look a little crazy if you have quite a few frames.
Thanks Again, TeamSDA_Dave
