Chained blocks bug?
Hello, I’m new here (french…) but using FreeWay from the very beginning.
Now I’m using FWay Pro 4.4.2 (build 5472) with a Mac Mini Intel Core duo, 1.66 Mhz, 1.25 Mo SDRAM under LEOPARD 10.5.1.
I design 2 HTML text blocks on a page, and use the chaining tool. OK. I put text in the first block and it flows into the second. OK. I publish my page. OK. I send it to SAFARI (ot FireFox) to see… AAARGH! The text of the first bloc spreads over the second one!
I UN-CHAIN the two blocks. Publish. View… same bad result.
I now make two blocks in a new page . NO CHAIN. I manually enter the text into block 1. Then into block 2. Publish. View… OK!
Isn’t that a BAD BUG ?
has anyone encounter this problem?
Thanks…
GdP
Is there an address for the page you are talking about?
Anthony
NO… just trying to start a new site - and not uploaded the page - because it is so bad…!
I’ve made other experiments: now when I put ONLY ONE text block in a page (and about half of it), when sending it to Safari, the text EXPANDS on the whole width… strange.
GdP
Just a thought
1st instance are the 2 html text boxes set as layers? If so greater text sizes will grow the boxes over the top of the other.
2nd Instance - is your text box set ‘width can grow’?
Why not upload the page in question to a test folder on your site where it wont be seen by casual observers so that we can see it.
Thanks…
I’ve closed FWay - and turn off my computer.
Restarted and relauched FWay.
I’ve made a new test with 2 HTML Blocks - not set as layers, not ‘can grow’ (previously same state!) — published…
AND NOW it works fine!?
Don’t know at all what has happened… Must make other tests. Conflicts with other apps? maybe…
many thanks!
I’ll will tell you later if the bug reappears… and upload the file this time.
GdP
