Hi,
No it’s not normal to have to edit Freeway output like that!
Just had a quick peek at your page and it looks like the return link isn’t getting set properly.
In Freeway go to >File > Document Setup and click on the Upload tab, check the address you have in the Web Address part.
If you are uploading to a folder (in this case zyzagarus) on your server from your Freeway document it should be:
<http://www.cmlmarketing.com/zyzagarus/>
This will link up with the actions on the pages to allow the cart to return customers back to the page they came from.
It’s been a while since I’ve used the actions but from what I remember this is how the return link is set.
When all the testing etc is finished and you are ready to upload the site to it’s final server, the link in the Upload tab of Document Setup should be:
http://www.mydomain.com/
Replacing mydomain.com for the real url, and don’t forget the http:// bit!
Hope that helps.
Steve.
On 26 Jan 2011, 12:19 pm, Mr worm wrote:
However I’m still unconvinced that this is normal practice for a shop?!!
Hopefully Dan J, Walt , Joe or someone familiar with setting up Mal’s shops in FW can shed some light on this subject.
Fingers crossed!
Here is my TEST link to my URL Dave:
http://www.cmlmarketing.com/zyzagarus/buybook.html
Or is it because of my site structure EG. domain/folder/page
Where as you stated that folder/webpage/webpage is not accepted - it must be folder/folder/webpage
Ultimately it will be www.mydomain.com/store.html
Worm
