I want to build out my website using Freeway, but would prefer a “pro” do it to start, then I would maintain/update it myself on Freeway. I have an existing site and simply want to emulate in Freeway (with any suggested design tune-ups). I also want links to my social media channels and, ideally, a running post of my tweets and blogs on the site.
Where are you located and do you have an example of the website you are talking about? Before one can give an estimate at least you should have a good idea what you are talking about.
Nice site, what software you use to build it? Why you want to make a
copy of it with Freeway?
The EditSpot that was used as a platform is unwieldy as a content management system, and lacks any support. I need more flexibility and control at this point.
Ok, the site has to be rebuild from scratch, first do a backup of all
images, backgrounds and screen shots in a folder, them sketch a site
map and links. Once done you most be sure that your FW version is
the same as the designer and both are in the same Mac OS. . Will be
helpful to know in advance what you plan to update yourself. How
much do you know about FW?
I have all the images and content on file. Also a site map. i am basically keeping what I have but tuning up some design issues. I am fairly familiar with FW Pro, but just do not want to do the initial work; better that I just update content.
Are you saying you are interested in contracting for this?
Please let me know if you have interest in doing this.
Thanks,.
