it’s top right on the home page with the fwd/back buttons.
For the life of me, I can not get it to work when I upload to server. It previews OK and views in Safari from the site files.
I have uploaded a completely different one elsewhere on the server and it works fine. Can anyone help as I have spent way too long on this one.
Try this: hold down the Control key and select Publish Everything from
the File menu in Freeway. Then upload to your server again. If that
doesn’t help, then locate the folder on your Mac where Freeway
publishes the site (the Site Folder indicated in the File / Document
Setup dialog), delete everything from within it, and publish again and
upload. In extreme cases, you may need to also empty your server’s
site folder and upload again. In 99% of these cases, what has happened
is that the JavaScript library that drives the effect has gotten
garbled by Freeway, or not uploaded, or renamed in such a way that the
page cannot find it. The “power upload” technique takes care of that
in the same way that a good forest fire is good for the grass.
Hmmmm! a bit scary having to re-upload everything for the sake of a banner on the home page. I think I will find a simpler solution this time. Thanks (as always) for your fast reply and knowledge. The site will shortly be having a makeover and I think I will wait till then.
