Hi Jonathan,
The structure of the tag itself is what identifies the item as h1, h2, etc.
How they appear visually makes no difference to search engines or other
devices trying to “understand” your site.
That said, best practices suggest your h1 text should act as a main
heading, with all following text including subpoint headers like h2, h3,
etc., in support of it. From that reasoning, it stands that if you have
multiple h1s on a page they should be divergent in topic, maintaining a
clear outline order.
My experience suggests things are much simpler when you restrict your page
to a single h1 topic and describe the diverging subtopics with h2 tags
instead. An example would be a page of different news topics (h2) under a
singular description of News (h1).
As I’ve said before, I think the key to good semantics is understand how
your content is relative and developing the ability to describe your
content in outline form.
Best wishes,
On Tue, Jul 10, 2012 at 7:45 AM, Jonathan Riddle email@hiddenwrote:
Hi all,
Is it acceptable to have more than one h1, h2, h3 etc etc tags set up on
a page but with different formatting? For example I have styles I have set
up as h1.10pxhead, h1.12pxhead, h1.16pxWO, h2.8pxBLK, h2.8pxWO.
It is not that I am filling my page with h1’s but just making sure they
all get seen as h1, h2 etc etc.
Jonathan
