CSS Header Help
Hi All
I would like to replicate the menu header in the link below,
Where the solid square goes to the top of the page when hoovering over the link.
http://themeforest.net/item/clinico-responsive-medical-and-health-template/full_screen_preview/7112924
Done the drop down part OK.
Any thoughts please
Mike
This can be done using the CSS Menus action. Use custom padding to add space to the top and bottom … the only thing you’ll need to add (or change) outside the Freeway User Interface is adding the transparent border (using the not yet supported rgba definition).
Richard
Thanks Richard - can you explain more please.
Not bothered about the transparent border, plus I would like the coloured box to stay on when on each page as per the home page of this template…
