This is a test demo page to replace the present website design.
My query is that the menu on the right (the French Menu) needs the sub-level to be on the left of the main menu.
If I do that then the arrow still points to the right (where there is no sub-menu).
I have thus not used arrows on the right-hand menu, as you see. Is there a solution to this or have I not read the manual correctly.
To do this you need to use a custom image. You can just make a copy of
the current arrow from your Resources folder (place it in your media
folder), import it into Freeway, rotate it and export it again to do
this.
is no sub-menu).
If you align the menu items on the right to the right and then set the
text direction to be right to left the arrows will appear on the other
side (on the left side) of the text, try it out.
