I have a fixed CSS menu on the side of a MASTER PAGE.
Simple white BG for both MAIN and SUBMENU settings. (I’ll pretty it up later)
There are 14 pages built off of the Master Page.
Several of the pages display the CSS menu correctly with white BG as it cascades out-- and some do not. The BG for these is CLEAR for the Main Settings, and some of the SubMenu settings on these pages
Can’t figure the reason.
Copy/ Deleting the CSS menu from the MASTER – saving all/publish all with no menu— then paste the copied CSS menu back to the MASTER so it reappears on all 14 pages… yield the same result. Some pages work correctly. Some do not…
All thoughts appreciated.
regards
TODD
