Just seen this so sorry for not posting the answer to resetting styles
ok this is how you do it
make sure you have external style sheet on
create a new style and paste this into the tag field:
h1, h2, h3, h4, h5, h6, th, td, caption
then in the extended button add this to name:
font-weight
and this to the value:
normal
now create a new style and this time called it this in the tag field:
html, body, div, form, fieldset, legend, label
then click the extended button and add this to name field:
margin
and this to the value field:
0; padding: 0;
if you wanted to add a base font to that last set then just add the font required so that would be as before in the name field:
margin
but add this to the value field:
0; padding: 0; font-family:Arial,Helvetica,sans-serif
ok this is the clever bit to make this the overriding reset styles in the style sheet
just add a space before the " h1, h2, h3, h4, h5, h6, th, td, caption" tag name
and a space before the " html, body, div, form, fieldset, legend, label" tag name:
then when you publish those two reset styles are before any of your other styles… well the ones that matter
all the bets max
