Hi, How do I get Freeway to point at an external style sheet? And not overwrite it when I publish?
You can use the External Style Sheet Action to apply a number of hand-
coded stylesheets to your page in a manner where Freeway won’t
overwrite them. Note that any styles defined in these sheets can only
be seen when the page is previewed, and cannot be applied inline. So
you will need to understand how to create styles that apply through
the cascade.
There is another Action in this suite that can turn an existing
Freeway page into a stylesheet, which then allows you to create styles
that you can apply through the Freeway interface.
not overwrite it when I publish?Cheers
great thanks!
