Css submenu problem in Explorer
Hello, I am new and having a lot of fun with Freeway, but I do have a problem now: I created navigation menus with submenus: in Firefox and Safari everything looks perfect, but in Internet Explorer the submenus do not show at all. Can somebody help?
Try adding a background colour to your CSS menu I believe that caused some problems with IE.
Also have a look at this thread.
http://www.freewaytalk.net/thread/view/35567#header
It is worth noting that the search facility in the online Forum is great.
Many problems are regularly discussed and revisited so its worth trying a search for previous threads on the area that is giving you a problem.
Thank you. Yes I had seen that. I do have a background color on the menu and submenu:
www.flairvoyance.com/collage
If you can take a look in Firefox or Safari, you will see it right.
Thank you for your help
Take a look at this link: http://www.freewaytalk.net/thread/view/35567#m_35567
Thank you.
If you looked 2 messages up, you would have seen that this link was already posted. I did say that i read it and still did not find a solution.
Any other ideas?
Sorry for being repetitive, but did you try this part of the thread?:
This is actually caused by the bug that has been mentioned before.
Go to Page>Insert HTML and in the “Before ” section (the / is important) paste the following:
li { float: left; width: 100%; }
Yes, I did try everything that was suggested on that post.
Thank you for your help. I quite do not understand how I did not read other people having the same problem other than that one…is it an isolated bug?
Hello again,
I still have not found a solution. I emailed Softpress and they told me to upgrade to 5.2.1 and to put a background. I downloaded the trial version of the latest Freeway and I created a blank document with just the css menu with background. IT still does not work in IE…(perfect in Firefox and Safari though)
I am quite at the end of my resources…I cannot believe that nobody else is complaining about this problem.
Can anybody help please?
Do you have a url to look at?
Nathan Garner
Partner
Austin Wells Design Consultants
1 Elmgate Drive, Littledown, Bournemouth BH7 7EF
+44 (0)1202 301271
http://www.awdc-creative.com
Member of NAPP
On 25 Sep 2008, at 20:10, EdR wrote:
Hello again,
