Hi once again!
ok, I want to use several particular fonts for my site and set it as a CSS style.
EG:
Helvetica Neue, light 10 pt
Helvetica Neue, Bold 12 pt
etc…etc…
I’ve noticed FW uses it default fonts, and also allows you to use fonts installed on your machine if you use the ‘force graphic character’ option.
However when you apply this it doesn’t always seem to match the font? Is this just me? Or am I doing something wrong?
I want to use the specific font style ‘Helvetica Neue, light 10 pt’ for bullet points!
I need the leading to be at ‘80%’ but once applied it doen’t seem to want to change at all?
Is this omething that cannot be alter due to the ‘force graphic characher’ settings or…???
Basically I have several different variations of fonts on each page within the site, only altering slightly…however this is crucial to the layout/look so I need the fonts to match!
Any help?
Secondly, is there a way to have multiple colours in CSS within the same paragraph?
eg:
• ‘red’ text… “black”
If you simple try and cheat - change the colour of the bullet, it creates a new style ‘style1 etc’ that will cause problems later with the CSS styling!
Finally!
Is there an option/action to allow you greater control over your text/html styles in CSS?
I have the font Hooge_05_53 NICE but different, when I ‘force the graphic character’ with this font it appears the same, however I want to be a able to alter the aa style like in ‘Photoshop’ – none/sharp/strong/crisp/smooth…
…as I want to use the “None” style as the font appears “FUZZY” even as html! This option if possible will allow me to set it to ‘none’ thus eliminating the fuzzyness!
Am I asking too much of FW? I hope not! hint hint!
Sorry to ramble but I’m getting frustrated an ddon’t want to have to use graphic text!
Not only do these issues compromise the look but also the SEO!
Hope your suggests/help can aid other too!
