Is there a way to add mouse scroller capability to the content box? It’s so great to not have the cheesy default browser scroll bars- I just think it would be incredible to have the custom scrolling area behave the same way. Thanks for a great tutorial.
Not with this particular javascript. There may be another out there that can do that, but I can see there will be a conflict with the browser window scrolling function.
Chuck,
Trying to get your scroll bar working. Followed your instructions carefully. Also downloaded your files, etc. Ftped the dom-drag.js etc. Wasn’t sure where to put it, so I added it to both the site and the mail folders. I tried my own implementation as well. Couldn’t get it to work. Help?
Mine: http://www.lyndacartersings.com/audioplayer/scrollbar.html
Yours: http://www.lyndacartersings.com/audioplayer/working.html
Thanks so much for your work on this - it is great and I’d love to use it.
Jan
Jan, I took a look at your two samples. Both are working at my end so I guess you worked it out.
Not sure what “mail folders” is but usually the javascript files go in the root directory same as your index.html page.
