Does anyone know if it is possible to customize the height of the CSS horizontal menu feature? This would also change the height of the drop downs as well.
The object is to get more color space around text in the menus.
actionsdev mailing list
Have a look at this thread http://www.freewaytalk.net/thread/view/45034
The principle is the same as you can use on your CSS menu
David, thanks for the response. The link you posted looks like solution I am looking for. I will look at it closer and put it into action.
