I typically draw lines without arrowheads and dimensions with arrowheads.
It seems like dimensions and lines share the same current settings, which means every time I switch from lines to dimensions I have to tell Intaglio to put the arrowheads back on. And vice versa.
Am I overlooking something or is there a much needed Intaglio enhancement needed?
Nope. Another one of Intaglio’s annoying quirks. You just have to get used to it, because I think most of the time, Nick’s out ‘on the piste’
A work around I use is to just copy a dimension line, along with its
arrowheads, and move it to where I want it.
enhancement needed?
