Bobby
(Bobby)
April 5, 2014, 2:55am
#1
I’ve noticed the address bar on my site is only showing the basic web address and not the specific page address.
For instance , when on my site Beatcynic.com , no matter what page I’m on the address bar says only beatcynic.com .
When I go to my site using the official address ,http://www.s#########.onlinehome.us/ each page shows its specific address. Such as, http://www.s########.onlinehome.us/blastedplace.html
how do I get that page to read BlastedPlace
This is fairly typical of a cheap/free web hosting package - they wrap your site in a Frameset which doesn’t allow bookmarking etc.
Unless you built your site this way - did you use frames in its construction?
Bobby
(Bobby)
April 5, 2014, 9:47pm
#3
Thanks for the reply.
I’m using 1 and 1 web hosting. Is that what you mean by “cheap/free” [not free] web hosting?
I don’t know if I built my site using frames. If I did ,I didn’t do it on purpose. I basically built the site using the Freeway guide years ago. I am starting the process now to modernize/rebuild.
I’m using Freeway Pro 6 now.
So your site is really at http://www.sXXXXXXX.onlinehome.us/
But the way your hosting has been set up is in a frameset so the Beatcynic.com site is shown as a frame at http://www.sXXXXXXX.onlinehome.us/
You should be able to get 1 & 1 to sort this - submit a support ticket asking them why this is set up this way.
