does not want to add arrow heads
I have yet deliberately to reproduce this curiosity but it has now happened twice.
I open an existing Intaglio file.
Draw a line.
Go to the arrow menu and choose At End
Nothing happens.
I can change the line colour but not add the arrow head.
Select all.
Copy.
File->new
Paste
Select the line.
Arrowhead gets added.
Any ideas?
Since I’ve had this version of Intaglio for some time, use it regularily and not noticed the behaviour before
it is possible I’ve tripped a switch somewhere???
Intaglio 3.0.2, Mac Pro, Snow Leopard 10.6.2
Julius
http://juliuspaintings.co.uk
I’m looking for comments re: http://juliuspaintings.co.uk/physics-of-thought
Intaglio mailing list
happened twice.
Draw a line.
Nothing happens.
Select all.
Copy.
File->new
Paste
Select the line.
Any ideas?
For what it’s worth, it has always worked and still works fine on
Intaglio 3.0.1, OS X 10.4.11, Dual 1 GHz PowerPC G4
Regards
–schremmer
tried here for Int 3.02 on Leo 10.6.2, in a new doc, arrowhead appears. Saved, reopened previous doc, all OK again.
Is your issue only when reopening a specific existing doc?
Hervé hi
I don’t know if this is document specific, in fact don’t know how to answer the question.
The curiosity as I call it has only occurred in the case of two documents, one created I think a fortnight ago - at the time I was not paying much attention to anything but the task in hand and I’m no longer sure which document it was. The other was created some six weeks ago.
I’ve just opened a different saved version of the identical 6 weeks ago file and tried to reproduce the steps which preceded the event but without success.
If I did indeed perform the exact same sequence of steps as I did earlier then the situation is curious indeed.
More data is required.
Perhaps tonight’s work will provide some.
Julius
