What would be even cooler would be if you were to use a
Timed.Observer to watch the form and set this back if any of the
existing values was typed in. I had a quick fool with this, and hit a
bunch of errors. My JavaScript Fu is too weak…
Thanks Walter and Mike for your help with this but I have another question.
I want to display my results in alphabetical order. I have a field ‘ID’ that will be used for this but I am not sure how/where to insert the ‘order by’ instruction into the code that I have
$query = "select * from sttasources where ".$searchtype." like '%".$searchterm."%'";
$result = mysql_query($query);
$num_results = mysql_num_rows($result);
echo '<p class="result14"><span class="body14VBG">Number of Members found: '.$num_results.'</span></p>';
for ($i=0; $i <$num_results; $i++)
$row = mysql_fetch_array($result);
echo '<TABLE BORDER=0 CELLPADDING=0 CELLSPACING=5 COLSPAN=2>';
echo '<tr>';
echo '<td WIDTH=100 VALIGN=BOTTOM HEIGHT=12>';
echo '<p class="body12V">'.($i+1).': ';
