Double lines under links
My site is doing something funny when I test it. I have linked some html text to other places in my site. This normally results in a the text being changed to blue and underlines the text. I normally change the color back to black and leave the link underlined.
What currently is happening, in some instances, is the texts shows up in the browser with two lines. The top line is Black and the bottom line is Blue.
Any suggetions as to how to fix this so that I have text that is linked, with one underline and black?
It would depend on how you were “changing the color back to black.” Are you using the inspectors “links” drop area under the paintbrush to set your link styles for the page?
Make sure that if you have the links style set as underline for the link state that it matches the visited state, but if you don’t want an underline to happen for the hover and active states you would still have to apply the “style” option and just not have any of the boxes pushed in. Freeway will then apply the style attributes to those link states of “text-decoration: none” which means there’s no underline for active or hover states.
I think those buttons to the left of it are goofy as I swear there’s three color “shade” states to those buttons. Yes, No, and Maybe.
Perhaps a link to the site would help figure it out.
