Drawing with an exact size?
Hi,
I have one (small) issue with Intaglio and can’t get my head around it.
When i want to draw something i always try do make something in size like 468px wide and about 200px tall.
I don’t know how to make a drawing of exact that size in Intaglio.
It’s clear to me that i don’t have to use that size for my drawing, since it’s a vector graphic. But how can i scale my drawing to that size?
The next would be to use snapping for that size…
What’s the answer to this problem? Make a rectangle with that size and draw inside it?!
Would be great to get a tip for this…Thanks in advance,
Zettt
Intaglio mailing list
Hi Zettt,
I have had similar issues, see the recent thread “Importing Bitmaps
1px Border Error”.
So I import a bitmap of a particular size and then check that my
export resolution is exactly right so that when I export the vector
art within the bitmap “canvas” I get the right pixel dimensions of
the vector art.
There may be other ways - and I’m by no means an expert with Intaglio
  • but it’s all I can suggest. Maybe others in the forum have a more
    elegant approach to this issue of vector > bitmap workflows.
Best Regards :slight_smile:
