It seems that, if I create a horizontal menu as the top in-flow item
in a div, the drop down submenus appear behind the in-flow item I have
floated and cleared below. This can be rectified by setting the z-
index of the lower item to -1, but (assuming I’m not doing something
odd) could the CSS menu action handle this automatically?
PS: I really like the new ability to select in-flow divs and use the
arrow keys to move between them, and find the spaces before, after and
between to insert new items. So much better than FW4. Thanks.
Freeway5beta mailing list
