Um, I dont know how to make one. Apologies in advance if its obvious!
stv
Unfortunately this outside the realm of Freeway. You will need another 3rd party application to do this, but if you have Photoshop you don’t have to look any further as that is built in to CS3 and beyond. Or if you have earlier Photoshop it came with Image Ready which does gif animations easily.
A little bit off-topic, but this may be relevant (and helpful) to some people reading this thread that are having problems with drop down menus.
When I designed my page in XHTML 1.0 Transitional and made the code ‘more efficient’ the menus did not work properly. When I changed it to ‘more readable’ it worked perfectly.
I don’t know if this is a known issue with Freeway Pro 5, but wanted to highlight it just in case others are having a problem with CSS menus and Transition FX
