David,
Okay, I’m pretty sure I don’t know what the last part of that means, but to answer the question implicit in the first part:
I created an HTML item and applied the E-Buy Form action to it. I then created to child items, and applied the E-Buy Button action to one, and to the menu item, I applied the E-Product Variation action. I have done this maybe fifty times on the current our web site, and in FW v5.6 it works fine. I have tried recreating the item both as an inflow child item and as an absolute child item, and it makes no difference. Within Freeway, everything looks fine. The shopform says (has variations).
I just opened a page from the v5.6 site in a browser, and it worked perfectly. I opened the same page from 6.0.4, and it failed. Nothing changed between the two versions except the output. I guess I can try going back to HTML4 and see if that works. Quel retro!
Choose Style
(6938) Three diamonds
(7456) Two blue diamonds
(6939) One blue diamond
Ring Size
Size-4
Size-4.5
Size-5
Size-5.5
6-Do not size
Size-6.5
Size-7
Size-7.5
Size-8
Size-8.5
Size-9
to this:
Choose Style
Ring Size
Size-4
Size-4.5
Size-5
Size-5.5
6-Do not size
Size-6.5
Size-7
Size-7.5
Size-8
Size-8.5
Size-9
does the trick, but the real trick is to get FW to output it that way. I’d hate to have to go back to v5.6. Any help would be appreciated. Below is the working page.
Thanks. Main point there is that outputting the same page with the two different version is the sole reason for the differences in the resulting code.
I appreciate your help.
OK David - just tried this in FW6 and had no issues using e-product variation.
Any chance you can send me just the single FW page i8294.html
A page can be copied from a FW doc into a new otherwise Blank FW doc. If you then do a File>Save Archive you will get a neatly bundled folder that includes all your mixings. Zip that resulting folder and email it to me - my email is on my People page at FWT.
This may be a construction method issue that doesn’t translate well to v6.
