so,…I’ve been at this all day…ugh. It seems my form page will send regardless of answering the math problem…no error messages comes up either …it just sends. might someone know the answer to this problem?
If your server is compatabile with ioncube then it is really very
simple:
1# Add the elements and give each one a name (that doesn’t start with
a number)
2# Add the PHP easiForm Element to each form element including the
submit button
3# Give the page an instance of the PHP easiForm action, in the action
insepector enter an email address and select the success page.
4# Add an instance of the PHP easiForm Errors action to an HTML box or
cell above your form ellements (and give it a style for the text).
5# Change your page to a .php page
If using with the math captcha…
6# Add an instance of the PHP easiCaptcha action to an HTML box or
cell between the last form element and your submit button and select
‘Math’ in the action window (give it a style for the text).
7# Upload to server.
In reality it is that simple.
Unfortunatly you are really telling me anythingcompatible as to why
you might have a problem, just that you have a problem… again, send
me the Freeway file (not resources just the FW file) and I will look
at it to see what you are doing wrong! it will only take me a very
short time to find the mistake.
In saying this, I will be out most of the day today so if you do
decide to send the file then I will look at it when I get back.
Mike
this problem?
Mike, thanks for your help. As I’ve said before, not all of the code was uploaded correctly to my host. When I re-uploaded your code all worked perfectly! Thanks for such great actions!
