I have an Airport Extreme and need to connect additional (3-5)
Ethernet-ready peripherals. I’m looking at NetGear hubs but welcome
other recommendations/insights/opinions. Belkin? D-Link?
I have an Airport Extreme and need to connect additional (3-5) Ethernet-ready peripherals. I’m looking at NetGear hubs but welcome other recommendations/insights/opinions. Belkin? D-Link?
I have NetGear here. I have a WiFi-enabled domestic one next to where the internets comes into the house, which routes the LAN via a long CAT5 to the back office. The office router is a more pro style NetGear gigabit ethernet jobby with all the sockets on the front.
Never had a problem with either.
Heather
Imagic Design * Good Design - No Compromise
email@hidden http://www.imagic-design.co.uk
Twitter @Imagic-Design
T: 01634 864017
Look for Gigabit Switch rather than a hub it should perform better. they
usually come in 8, 16 or 32 port variants. Netgear should serve you
well. I suggest you specify one without fans because they can be
annoying if you work in a quiet environment.
Don’t forget, you will probably get and need more ethernet connections
in the future, so best to over specify.
Heather
T: 01634 864017
Update your subscriptions at: http://freewaytalk.net/person/options
Todd mailto:email@hidden
9 September 2012 18:42
I have a couple of TP-Link 5-port gigabit switches (available on
Amazon). Inexpensive but have been completely reliable. Another make
at a similar price is ZyXEL, which seem a bit more sturdy as the cases
are metal.
Roger Houghton mailto:email@hidden
September 10, 2012 6:51 AM
are metal.
